It's probably "absolutely normal." It PROBABLY did this from the getgo, it's just that you happened to notice.
But you MAY have a problem. What sort of alternator do you have?
Super duper big Denso/ some other late model conversion?
Mopar "stocker?"
Moper "stocker" PARTS STORE REBUILT?
The above questions can have a huge effect. You have a radio? Any abnormal noise in the radio on AM? (raspy musical note?) Would indicate 1 or more bad diode
How about the ongoing "bulkhead connector?" If this is degraded from years and years of, well from years and years, you undoubtedly are dropping some amount of voltage on the way in/ out of the connector
You could consider having the alternator tested by one of the dime-store parts store testers, BUT VIEW THESE WITH A SIDEWAYS EYE. They are built to "sell alternators" and most cannot tell the difference between "full output" and one that "just works"
You have a multimeter? There are some tests you can make yourself, stay tuned.
