It helps to make sure you select the correct usage request, drag or street. I didn't catch it until I got the recommendation yesterday, surprised me to say the least. Everyhing is determined, just taking time on the cam choice to see what rolls in. He spec's a. 316° duration "At Seat" ,260°@.050", .378" (.585" w/1.6 rocker) 96° overlap, 110°LSA, a .875" lifter lobe single pattern grind. (Edit: 316°duration is at seat, not after lash but what the duration is who knows)
