What do you guys think?
That looks killer. Are you powering stock headlights, or did you convert it to a conventional light bulb? If you are using the stock lights, what did you use as a powersource? I have a '70 Duster tail panel I'd like to do the same thing to for my son's room.
Thanks guys really appreciate it. I am in need of a 68 "Plymouth" script for the header panel, I need a POS.
Pic.1 and 2, this is the set up I used: Two door chime transformers, 12v at 10 amp max outputs and fused at 7 amps, the left transformer feeds the left side lighting and the right transformer feeds the right side lighting, I installed an on/off (dpst) switch that controls the transformers that are hooked up in parallel and are being fed by a power cord (120v).Any way you can post some info on that setup? I would love to do the same thing with the taillights that I have but don't know enough about electrical to figure out what I needed. I was looking into a power source like might be used for a laptop, or video game or something. Something that plugged into the wall but had a 12V output. Not sure if I'm on the right track or not. Thanks.
Nice !
I used to have a piece that would be good for the other side of the wall .
http://www.forabodiesonly.com/mopar/showthread.php?t=66370&highlight=Art
