My old Demon
5.7bob
Found the original window sticker with VIN NO. LM-29-1-18-26C474 I am going to see if it is still around. DMV closed today have to try Monday.
You may have a hard time doing it. Your first 1 should be a letter and the 8 is a B. The last 6 digits should be all numbers and no letters.
In Cali , the DMV's v.i.n. check doesn't recognise the pre-1981 v.i.n.'s ( e.g. , the 17-digit v.i.n.'s ) ; I'm not sure how other states v.i.n. checks work ...
You are right. A better look and a magnafying glass helps. Hamtramck Assy LM29-H1B-260474 S.O. NO113-8L124991 color code X9 TRIM CODE M6X9
Thanks I sent in the form today for a title search.
