JoeDust451
- Joined
- Jul 1, 2005
- Messages
- 1,348
- Reaction score
- 27
Who out there is on the bottle, wondering how you have your tune, how much are you spraying, How much are you knocking off your ET?
my plans with the next motor is for nitrous...there actually seem to be quite a few nitrous haters on this site (and in general everywhere too)...i guess people cant understand that just because the power is coming out of a bottle instead of a hairdryer its still legit (maybe because it bugs em when they lose?) lol
nonetheless, interesting to hear mopar nitrous combos...not too many that ive seen
Back in the late 70's early 80's we didn't know all the "details"...
Ran a stock type engine (cast pistons) with a NOS brand 100 shot plate.
Before- the car (duster) ran 13.70's at 102 for a year, week after week, drive in, run.
After- 12.60's at 110, drive in run, drive home,,3.55 gear, capped up, street tires
....always ran 7psi fuel pressure...got about 7-8 full runs per bottle.
no electronics, just mashed a button when I left. Never any problems
Engine came out in 86 and is still on a stand over in the corner...
JMO butI hope that car is way lightened. I dont think unless it's less than 3200lbs with you in it that it will run those ETs. I'd like to see another full point of compression at least (preferably 1 1/2 points), another .050-.080 lift, upgrade the rockers, and an intake like the M1 with a 2" open spacer or the Victor Jr. At 3400lbs in a street/strip car you need to make 600hp at the crank to go 11.0s N/A. That's asking a lot of 270cfm heads and a roller that will end up .610 at the valve. You need to get the valves open to .700 if the heads flow that high and the rockers will not take that much spring pressure.
