ronw
Installed the Napa timing chain on our 68 dart 340. After it was installed it had at least a 1/4" play on each side. Has anyone else used this chain with the same play? What chain should I use?
Yep!
I’ve used the same also used the cloyes from jegs 9-5387 they all work great
I never understood how that tensioner survives. But it does. Seems like the chain would saw it in two.
I'm almost sure that it was not.By chance was your block align bored at some time? If so your crank will be deeper in the saddle and closer to the cam making the timing chain slack.
Who said Edelbrock?Can't believe you guys are using those edelbrock timing chains.
Amazing where some of you decide to "save" money.
The pictures that are posted in this thread of timing chains, they are all edelbrock gears, aka corner parts store crap.Who said Edelbrock?
Cloyes has .005 and .010 shorter versions of their 9-3103 Race True Roller sets.
This is the correct fix for a block that has been align bored.
They make the sprockets a little larger in diameter. They must be used as a set.
The block has not been align bored. What is a quality chain set to use without these problems?I recall that it was a reliable source, but don't remember who, when or where. (Possibly Cloyes.) But I believe that the difference is made up by the chain length, not the sprockets. They sell replacement shorter chains. If the sprockets were different, they would have used the same chain as standard sets.
Cloyes True Roller is probably the best.The block has not been align bored. What is a quality chain set to use without these problems?
Good chain, that is what I ended up using.Cloyes True Roller is probably the best.
