[SOLD] Narrowed 8.75
ronw
cashtown,Pa.
Rating - 0%
0   0   0
View attachment Rear End 8.75 #2.jpg8.75 narrowed to fit a 68 Dart mini tubed. has 4:88 spool with gun drilled axles. Bearing retainer to bearing retainer 49". Spring perches C to C 35". The rear housing has a back brace and brackets for a wheelie bar. The rear is complete with backing plates(W lining and W/C), Drums, and Two Convo Pro 10" Wheels( 4 1/2 back space) with mounted 30.0 X 11.5-15 GoodYear slicks. Asking $950.00 In Gettysburg, Pa area. pick up only no shipping. I'll post pic's as soon as I figure it out Thanks Ron
Hi I have a 70 duster and I'm wondering if this will work in my car if I minitub it?
Both are "A" bodies. But with out measuring I'm not sure. Thanks for inquiring Ron
Baad GT
I just measured my frame rails. Above the rearend it measures 38 1/4" from outside to outside of the rails. If this is the same as yours it will work for sure. Ron
Ok when I get home from work I will take a look. Would you be able to meet me in the middle somewhere you are about 3 hours away
