[SOLD] Narrowed 8.8 Ford rear end
bb66cuda
San Jose, CA
I have two narrowed 31 spline Ford 8.8 rear ends available. One is a 3.73 limited slip and the other is a 4.10 limited slip differential. They are narrowed to 56 1/2” mounting surface to mounting surface. Have been gone through with new e brakes, rotors, calipers, brake lines, rear cover, bearings, seals and shock perches. Perches are 43” center to center, correct for an A body Mopar. Inside rear end has been completely flushed out and degreased after being narrowed. Outside has been cleaned and painted with POR15 satin black paint. Comes with u bolts, will need shock plates for your application. Price is $1000 each. Located in San Jose, CA.
DUDE. How do you have so much cool stuff?!? That would be PERFECT, as I'm springing for Wilwood fronts (red drilled kit for early A bodies, direct fit!) and heading out in an hour to buy my 16" American Racing wheels.
PM heading your way.
In box is still full...3.73 is what I am looking at...
I have sold the 2 pictured and am in the process of making 2 more identical to these. After that I won’t be doing any more of them.
Let me know when they are done...Thx!
I am interested in one. Please message me when you have time.
