Need 340 mounts for a 72 Demon
northeastmopar
Massachusetts
Looking for the correct pair of stock motor mounts for the 72 Demon with a 340 engine. Anybody out here got a spare set they are willing to sell? Thanks
pass side is the same , driverside on 340/360 is the same but 318 different
Hi, I have set of solid motor mounts for you these are the same as factory they just have a steel block in place of the rubber and you could replace the steel block with the factory rubber
Asking 80.00
Left side 318-far left,
Left side 340 -center. will fit 360 also
right side 340,318 -far right. will also fit 360
