GoodysGotaCuda
Mr. Goody
Alrighty, first off my 360 that I have for my Barracuda seems to be some kinda fluke build. It is cast on the passenger side of the block 1983, it is a Mopar Performance block, however another stamped number on the block decodes to 1987...but! Its also cast with number '53020006' which says 1992! wth?. it's also setup for a roller cam. Pretty odd block. Anyway, I'm looking to find out if I have to run Magnum heads on this sucker or will modifications be needed to run LA style. The previous owner had a flat tapped hyd cam with LA eddie heads on it. Apparently it ran good...but consumed oil...which I wonder if is related..
What can I look at to tell me if this block feeds oil to the heads via the rocker stands, or via pushrods?
Attached is a pic, again cast 1983, stamped 1987, casting number is a 1992 but setup for a roller cam. Doesnt make much sense, but ill go with it lol.
Anyway, what to look for on how the heads are oiled? And do i have to run magnum style rockers with roller lifters/cam?
