n8ling
Best way to visually id cone or clutch type posi?
easy. you are talking 8 3/4 Differential, right?
X cast into the side of the housing...... 741 housing....cone-style, IF equipped
9 cast into the side of the housing......489 housing....cone-style, IF equipped
2 cast into the side.......742 housing.......CLUTCH-Type, IF equipped.
Clutch type will have bolts holding it together, while the cone does not.
