Need column shift linkage and throttle cable for 66 'Cuda
Its a on the column automatic. The linkage I really need is from the column down to the bellcrank but I would take it all if someone has it.
OK, got most of the linkage issues worked out, had some parts and pieces off a belvedere I made work. Now I just need the "stick" that goes into the column. It was missing in the Belvedere and I'm not sure what else if anything will fit. Any help would be appricated.
. . . .Now I just need the "stick" that goes into the column. It was missing in the Belvedere and I'm not sure what else if anything will fit. Any help would be appricated.
I'm guessing you need the shift handle. I have several from 65 and 66 A's
