Need dimensions...
grassy
Nova Scotia
Would you believe we have lost our brake pedal bolt.
This should be the item:
Could someone give me the dimensions of the larger section and the smaller section ? I can have one made here.
I need this for safety inspection..
Thanks
Ian.
maybe someone can measure the hle..got to get the car out of the garage..and I think I may have one but it doesn't quite look like that one..the shoulder is shorter...
Is this for the pedal to rod?
My rod sitting here on the desk measures .577 inside diameter. The shoulder appears to be .554
Bruce,
I just found a bolt. The shoulder seems to be shorter. My battery has gone on my electronic side but manually, the bolt is:
10 units = 1 inch
1 and 7/10s long
shoulder is 4/10s long
thread section about 1 inch long
Shoulder 6/10 wide
threads 4/10 wide..
Do I have the right bolt ?
ian.
Not sure, I measure the inside diameter of the MC pushrod and the width respectively where it attaches to the pedal..
Try it and see if it fits.
