Need Disc/drum combination valve------
DesertRat
Leading edge boomer
Moses Lake, Washington
OK, I spent the time doing due dilligence on the brake forum about the disc conversion thing. I am putting 70 Duster KH discs on my Barracuda and I really want a factory combination valve to replace the existing drum/drum divider block. I am using a 71 Duster disc/drum MC and have run my own brake lines before so that is not an issue. One of you A-body guys who changed from the SBP KH setup to the later LBP setup must have one around you are willing to part with for a price????????
Let me know, I am ready to buy.
Rat:-D
I have one off of a '72 Demon with disc/drum. $45. shipped to you.
Ted
You can also try Inline Tube (inlinetube.com)
Here is what I found that may work for you:
"BLK245
1967-74 A-body Distribution Block - Dart / Duster / Demon
Brass 5 Port Valve Disc or Drum Brakes
Brass
$89.00
and or
Valve Notes:
For use on 1967-74 A-body Mopar with either disc or drum brakes. "​
I hope this helps.
Thanks,
OldMoparsRule!
Thanks guys. I would like the factory original type, not the aftermarket type. I will buy one of the ones offered. PM's sent.:read2:
