Need drivers door latch assy
blown340
Chico, Ca
Hi for my 70 duster i'm in need of a few things
Door latch assy...drivers side...just to be clear,the inner rods all connect to it and this locks around the post on the body
I am also looking for the following small items
2 centerline center caps for my rear wheels...the hole in the center of the wheel measures 3 3/16"
Left..or both if you only want to sell a set...the plastic cover inside the trunk for the tailights.
And last is this small rubber square that goes on the end of the rod that rubs up against the truck hinge. They are the 2 rods that help hold the trunk up.
Please let me know if you have all or any of these....or where I may find them.
Also any one recommend a mopar wrecking yard that they deal with.
Thanks John
