Need for deep pan
my favorite pans are off jy RE transmissions. They were deep from the factory to clear the solenoids. Adapters to move the filter down are readily available.
Next to dirt heat is an automatic transmissions worst enemy. If the trans cooler is big you should be ok, but a little extra never hurts.
Especially nice because the stock pans don't have a drain plug and the deep do. If you are servicing your Trans with a OE pan and have to remove it now is the time to go deeper!
