Need Help Asap Please!
GermzD74
Cool Member
San Diego, CA
I'm in need of knowing where the wire that's connected to the HORN RELAY on the side of my glove box goes to...my car had it cut off or something because I cant find it...I want to get it from another dart through the internet and need to explain the guy exactly what wire that is, any pictures? where does that cable on the relay go to? THANKS! :tool:
Thanks Gremlin I already took a look at that and i seems that the horn relay has three wires going out to different places, the Dark Green-Red goes out through the fire wall to the horn, the violet to the fuse box, and the black to the horn switch? but why cant i find them all together as they should be I tried following them but cant seem to find them going out to the glove box where the horn relay is at...why...lol whhhhyyyy!!!!
hmmmm
I went to the JY and looked at a 75 Duster they still have. The plug was right next to the left side of the glove box. All 3 wires were hooked to a red plug that was attached to a relay. Those wires are part of the main wiring harness. If you reach up under the dash to the right of the ashtray, there should be several wires taped together. Some run to the horn relay and some run to the door switch. It should be easy to pull the harness from under the dash and look for where the wires are cut. If you can use the harness out of the Duster let me know.
