Need help gaining access to ignition switch
Mopar to ya
Rock Creek, Minnesota
I need a new ignition switch, and while I'm at it, I have an ignition lock cylinder that matches my for keys I am going to put in. I am having trouble getting the middle section off the column. I thought there was a bearing around the shaft that would slide off with a little persuasion, but the whole shaft pulls up an inch or more. I can see the prize behind, but this piece has to come off. Is there a trick or does the shaft come out with it?
See that C clip that's up against the bearing?
It has to come off.
I made a puller to use those 3 screw holes and work against the shaft once you get the clip off.
That's how I do it.
