Need help on electrical part of resto.
Airborne_Tanker
Louisiana
Ok so a while back i was gonna see if i could finally start my duster with the key so i took off all the parts to run the engine off of just the coil and a battery. Now i know i need an Ignition Box but also i am wondering would not having one of these stop the headlights and all from coming on. I would like to test it all out and see if i need new lights etc. but when i tried nothing happend. Any and all help is needed in this i would like to atleast have my lights and all be able to turn on soon as i am trying to make Crusin' the Coast in it this year. So if anyone knows what all i need to start it or atleast turn the lights on let me know. As far as i can tell from the diagrams ive seen everything is hooked up correct. I will also change all the fuses today.
Also for the cars info it is a 75 Duster 360.
First question DO YOU have a 75 copy of the Chrysler shop manual for your car, either print or CD.
I don't have 75 wiring diagrams, but do have 74 Might be of some help
Do you have the ammeter hooked up?
Is the fuse link at the bulkhead good?
What exactly works and what does not?
Factory wiring, I assume?
Have you pulled the bulkhead connector apart and inspected it?
yea i used a 74 diagram on it. im guessing by bulkhead you mean the connectors on the firewall if so i havent touched them. I havnt been inside anything electrical cause i no nothing about it and is all factory wiring.
