The studs for the seats go through the floor. There should be four (4) nuts underneath the floor pan, one at each corner of the bench seat. Undo these, and the bench should lift straight up. Any wiring will be fairly obvious underneath the seat, above the carpet. (I believe in 1974, there were some wires running to seat-belt monitors, but I'm not sure). Make sure to check for wiring before yanking it out.
Good luck.
-Mike
