WHATAREWEWORKINON????
1947 Whippet?
Supermarine Spitfire?
American La France fire truck?
There is no "one wire," and you use the ORIGINAL "two" wires.
Traditionally, the dark blue "ignition run" comes out of the bulkhead and is hot ONLY in run, NOT start
It powers the ballast resistor, the regulator IGN terminal, and on 70/ later cars, feeds power to the blue alternator field wire and a couple of other things.
YOU NEED that wire.
BUT it is NOT hot in "start."
The traditional brown comes out of the bulkhead, and feeds the coil side of the ballast. It is hot ONLY in start. If you are removing the ballast, you need to hook the blue and brown together, and run that junction to your coil + and to the "hot" terminal on your HEI, as well as leave it hooked to whatever else it supplied, IE regulator, alternator blue, etc etc.
