Blue Grey Duster
I was reading the advice that was given to the other post," need help with 360/380 hp crate motor tech info, so as not to hi-jack the thread I starteda new post.
Other post- Need Help on Magnum 360/380 hp Crate Motor Tech Info
I have the same cam in a small mopar magnum crate stroker motor. So what converter, gear and tire combo would you recommend for the street?
Here is some info. from an advertisement.
Brand:Mopar Performance
Manufacturer's Part Number:5153474
Part Type:Crate Engines
Product Line:Mopar Performance 402 C.I.D. Magnum 435 HP Crate Engines
Summit Racing Part Number:DCC-5153474
These Mopar Performance 402 c.i.d. have identical 4.00 in. bore and stroke dimensions. with 435 hp, and 457 tq at 4500 RPM. Magnum R/T cylinder heads with big stainless steel valves (2.02 in. intakes, 1.625 in. exhausts), heavy-duty valve springs, and 9.0:1 compression ratio. The intake is a tall, single-plane, single 4-barrel M1 type. stock, The camshaft is a hydraulic roller type, with a 0.501 in. intake lift and a 0.513 in. exhaust lift. Intake duration is 288 degrees; exhaust, 292 degrees.
230/235 @50 , 108 lobe
I don't know anything about cams and converters, and this is in a Duster, 727, tti step hedder, ( 3310 currently).
So what converter, gear and tire combo would you recommend for the street/ strip? Being a stroker, I'm limited to Rpm's and how does my torque effect the converter size?
