Need help
hdriders
Member
Bristol, Va
I have a 1973 Scamp 408 stroker that I built a couple years ago and I'm going to sale it and not sure what its worth. Here is a little bit that was done new paint, bumbers rechromed, 8 3/4 sure grip, new tire/wheels, floor pans, 408 stroker kit, alum.heads, m.s.d. ing., alum radator, i can keep going but you get the idea. Any ideas help or interest.
Thanks Scott
Ill be the first (of many I assure you) to let you know this question is difficult to answer, but pretty much impossible without all kinds of detailed photos. Undercarriage, all the usual problem areas in window channels, bottom of the qtrs, under the hood etc. then some of the experts can chime in.. good luck on your "appraisal" and sale.
chris
