Need help!
DesertRat
Leading edge boomer
Moses Lake, Washington
I am putting my 67 heater box together after completely dismantling it. The attached photo shows the only parts I had bagged up that I dont know where they go.
Help anyone???
:coffee2:
The metal strap goes on the blower motor to body mount bolts for it's ground, and the others look like wire clips to hold the wires where they route.
I'm positive on the strap and 50/50 on the clips. :D
There are clips that look like those used to keep the defrost tubes attached. Creates a tooth of sorts on otherwise smooth plastic. As for the ground strap... I don't recall one on the blower motor but nobody should rely on my memory. I know for sure there is a similar ground strap on the wiper motor. Hope this helps
Thanks guys, that makes perfect sense. I have the wiper unit in so I will have to check them both out.
Appreciate the help. DR
Just a little hint for next time:
"need help" is not a good plan for a thread title.
That could be a wiper motor ground, and the others could be defrost tube clips.
I guess I assumed since he said he bagged up the stuff for the heater assy that it had the ground strap. (But it SURE does look like the wiper ground strap)
