Need Parts 64 Dart (Super 6)
HollywoodDart
Member
Hollywood
Rating - 0%
0   0   0
Hi, looking for the following:
Thanks for looking! Am located in LA.
* V8 throttle linkage/gas pedal
* Hinge bolt for convertible frame
* Dash pad
* Door panels
Not bein smart or nuthin, but why not get all that fixed? Every bit of it can be repaired or reconditioned.
You're right as far as the vinyl bits go, but vinyl repair can be quite expensive, at least more expensive than getting junked parts.
As for the metal piece, yeah I've looked into having that recreated, and I might have to down the line, but again super pricey to have done. Other option is just to buy a whole frame, again possible, but we're looking to keep the budget down here.
Of course if you had some inside info on a horse or somethin, I'll be able to buy whatever I want. Might even get the girl painted finally!
* Dash pad
* Door panels
I have a top frame that I'll be putting back on my 66 dart and can see if a friend can lathe one or 2 pins up for me(if I can get the pin out,is it set in there with a roll pin?) gimme a couple of days to try and get hold of my friend.
That would be amazing!; cheers for the effort.
And yup, it's just in there with a simple roll pin, should pop right out for you.
