need pics - clamps for lower rear seat back
str12-340
Vashon, WA
On 'later' Darts (74-76?) they moved from the earlier tabs that you bent over to a little one bolt bracket to hold down the bottom corners of the rear seat back. I had them on a 75 Dart which is long gone. Does someone by any chance have a picture of one of these little brackets, or better still a picture of one that is in place one a car?
Thanks for your help!
A picture of the bolt in type? Or the bend over tab? The seat or the body. I have bodies here with the bend over type and seats for that model 67-71. I have seats with the bolt on bracket but no car here. That would be 72 and newer
I'm trying to get a picture of the bracket on the newer seat, is it welded to the seat frame? Somehow I thought that it was loose and just clamped the seat frame with the bolt...
Don't know if this what you're looking for
Thanks, but no it's not - that one holds the seat bottom in place and the one I'm looking for are the ones that hold the bottom of the seat back in place.
