gold68dart
This is my first try at building a new motor for my 68 dart so I thought I would turn to you guys for some input. Here is what I have so far:
340 block stroked to 416
SCAT rotating assembly
final compression about 9.8:1 to run pump gas
Hughes cam .548", 237 dur, 108 LSA
Eddy Air Gap intake
Eddy RPM heads - non ported
750 holly dp carb
3:91 gears
4 spd
1. Does the above combo seem like they all fit or did I make a wrong choice with something like going with a single plane instead of dual?
2. What kind of horsepower should I expect?
3. Can I expect mid 11s in the 1/4?
4. I plan on headers - Dougs or TTI?
5. Is the stock coil fine or should I go to something like the MSD 6AL?
Thanks!
Eddy Air Gap intake
750 holly dp carb
3:91 gears
4 spd
Thanks!
