Need some parts to build a 68 cuda 340 S clone
eschroeder1
A-body Freak
Texas
Floor shift steering column for power steering
Front bucket seats with headrests or 1970-74 high-backs
4 speed pedals and floor hump
340 long block
340 A body exhaust manifolds
SB power steering brackets
SB alternator brackets
150 MPH speedo
Factory center tach
AC dash bezel
8.75 rear end with SBP axles
SBP ralley wheels 14x7's
three spoke sport steering wheel
clutch linkage
Let me know what you have and price
Thanks,
Eric
i hate to plug another forum but you should check out the 67-69 barracuda owners group on yahoo, for these parts. there's a couple thousand members all with 2nd gen cudas. wiff 67-440 cuda
I have one part only, the 340 square bore intake manifold....cheap. You will have to somehow remove the busted off bolts at the thermostat housing, and the bypass hose inlet needs to come out. Someone used something like epoxy in those areas. I am in northern [email protected]
Complete smallblock/4-spd set-up. bellhousing, shifter, linkage, pedals,clutch linkage, trans. $800 +S&H
