340plot the bushy bush Joined Jan 24, 2010 Messages 5,019 Reaction score 38 Location va Rating - 95.8% 23 1 0 Jan 8, 2012 #1 Contact seller guy, i am desperate for clutch pressure plate bolts and 4 speed flywheel bolts asap please let me know!
naji408 Well-Known Member Joined Apr 11, 2011 Messages 200 Reaction score 33 Location Sunnyvale, CA Rating - 0% 0 0 0 Jan 8, 2012 #2 Summit sales the kit...call them up.
highflyer Well-Known Member Joined May 10, 2010 Messages 1,499 Reaction score 39 Location oakley ,cal Rating - 100% 29 0 0 Jan 8, 2012 #3 IV got a set of mopar flywheel bolts[pay the shipping] want them or are you using summitt ..jim
340plot the bushy bush Joined Jan 24, 2010 Messages 5,019 Reaction score 38 Location va Rating - 95.8% 23 1 0 Jan 9, 2012 #4 guys, anyone got a set of flywheel bolts, or know the thread pitch and length, so i can find a set at napa? thanks
naji408 Well-Known Member Joined Apr 11, 2011 Messages 200 Reaction score 33 Location Sunnyvale, CA Rating - 0% 0 0 0 Jan 9, 2012 #5 http://www.summitracing.com/parts/DCC-4529113/ Thread size is on there
scuba0331 Well-Known Member Joined Jan 31, 2008 Messages 1,032 Reaction score 17 Location Ohio Rating - 100% 2 0 0 Jan 9, 2012 #6 naji408 said: http://www.summitracing.com/parts/DCC-4529113/ Thread size is on there Click to expand... I bought that kit too! Here is the napa link. http://www.napaonline.com/Catalog/C...BK_6151553_0313469585&An=0&Ar=AND(P_RecType:A) Part Number: BK 6151553
340plot the bushy bush Joined Jan 24, 2010 Messages 5,019 Reaction score 38 Location va Rating - 95.8% 23 1 0 Jan 9, 2012 #7 thanks for the links!. i have no way of knowing how to move around those chebby sites! now, do i need to use washers on any of these? for flywheel or pressure plate bolts?
naji408 Well-Known Member Joined Apr 11, 2011 Messages 200 Reaction score 33 Location Sunnyvale, CA Rating - 0% 0 0 0 Jan 9, 2012 #8 Just some locktite will do.
340plot the bushy bush Joined Jan 24, 2010 Messages 5,019 Reaction score 38 Location va Rating - 95.8% 23 1 0 Jan 9, 2012 #9 one last question. is there a difference between an automatic flexplate bolt and a four speed flywheel bolt. length wise?
naji408 Well-Known Member Joined Apr 11, 2011 Messages 200 Reaction score 33 Location Sunnyvale, CA Rating - 0% 0 0 0 Jan 9, 2012 #10 They're the same size.
JohnRR This space for Rent Joined Dec 4, 2008 Messages 715 Reaction score 31 Rating - 0% 0 0 0 Jan 9, 2012 #11 naji408 said: They're the same size. Click to expand... No , they are not , the flywheel bolts are longer and have a short head to clear the clutch disc hub , hardware store bolts will not work . No washers under the flywheels bolts , lock washers under the pressure plate bolts .
