[WANTED] Needed door opener inside
gdizzle
los angeles
Need complete door opener assembly for 1966 dodge dsrt sedan 3.7. Driver side. Current stem in door panel is ruined. I have door handle, but it con. No longer fit on the stem as stem was drilled out.
H,elp plead.
Tony, I think he needs the part the handle mounts on with the rod to the lock. the post handle is stripped.
