NEUTRAL SAFETY SWITCH HARNESS ROUTING QUESTION
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
Does anyone have any idea where Ma Mopar ran the NSS harness on a 1971 demon with 727? I see a harness clip on the pass side where the tail shaft meets, and there is another one sliding loose on the harness that looks like it clips into something. The harness looks too long to run as the crow flies to the NSS.
Thanks FABO
P.S. While you are at it, how about the main battery cable route as well. I got this darn car in a pile.....Or several piles :)
Where it turns upward in the image, it goes up to the firewall harness clips and then turns and runs toward the bulkhead where just before it, 2 of the wires terminate into connectors. the 3rd wire continues to the DS inner fender and along the forward light harness and out at the starter relay.
Awesome. Thank you for the help :thumbsup:
