new 340 engine start up questions
You just made my brain hurt. I was going to bring it to TDC on the balancer and make sure the rotor is at #1 when I fire it and adjust as need be. What do you recommend?
Make sure you are on TDC No. 1 firing....as the damper goes by twice once for no.1 and once for no.6...
that is what he is trying to explain above....
How do you check that you're on #1 if your timing cover is already on?
what I do.....on a new engine...
went I set the distributor for the last time...after priming the engine...
while turning the engine by hand....I watch the No. 1 intake valve....after the intake opens and closes.....went the damper goes to TDC again...No 1 will ready to fire....
