moparraceman
SALE PENDING 1970 340 7-8-70 NEW SHORT BLOCK never started, has been bored .030 over ,new pistons,rings, R&M bearings .double roller timing chain,has steel crank with windage tray .arp bolts in rods ,arp head stud and main stud kit . has new oil pump and pump drive.has swival oil filter adapter .has milodom oil pan and pick up .complete assembly has been balanced.has new solid lifter cam in it now 520 lift also if you want hyd instead , have a new 509 hyd with new mopar lifters $2500 pick up mansfield ohio
