archerandethansdad
You can probably increase the cylinder pressure and performance by advancing the camshaft timing some.
Yeah right now it's at TDC but the cam gear i got wasn't adjustable. I assume that's what you mean?
That is WAY low. You should be around at least 130-140. If all cylinders are at 100, you need a COMPLETE rebuild.The compression is 100 on the nose every cylinder.
Did you degree in the cam when you installed the new cam?Yeah right now it's at TDC but the cam gear i got wasn't adjustable. I assume that's what you mean?
Maybe with all the help here, if heeded, the OP can maybe improve things, but that’s way too big a cam and without changing other parts (big ticket items and/or more involved labor) i think he’ll be underwhelmed regardless. RRR’s advice on degreeing it in at 102 or so might be the best advice that’ll make the most of the situation.This Is a severely UN-balanced combination.
If he digs deep enough to retard the cam he might as well pull it and replace it.Maybe with all the help here, if heeded, the OP can maybe improve things, but that’s way too big a cam and without changing other parts (big ticket items and/or more involved labor) i think he’ll be underwhelmed regardless. RRR’s advice on degreeing it in at 102 or so might be the best advice that’ll make the most of the situation.
The Summit cam is a “In general bump up cam” that I don’t recommend myself. I firmly believe that another cam would be very well more suited to making some “Upgraded Power” to enjoy. This is where paying the piper is worth the expense.Yeah its the summit cam. I wasn't looking for a strip car. Just something with a nice sound and decent response. Otherwise i'd have dropped 4-5 hundred on a hughes cam.
Probably so. I say your cam is ro large and the cylinder pressure to low on a small displacement engine. Further hindered by a low stall and the 3.23’s. There is t much ceiling above to reach for your n this combo and a tiring engine.I ran the compression test again and 1,3,7 were all 120 (factory manual says 125-155 so not disappointed at 200k miles) 5 was 135. 2,4,8 were about 125 and 6 was 130. So not as low as originally quoted. I'm happy with the sound and it does seem to pull harder then it did before. New pistons and rings are on the list but doesn't seem to be as pressing as originally thought. It doesn't smoke when started and oil pressure stays right around 50 at idle and 75 when driving. I think my expectations were higher then they should have been.
Carb and timing tuning is where i would start.Yeah its the summit cam. I wasn't looking for a strip car. Just something with a nice sound and decent response. Otherwise i'd have dropped 4-5 hundred on a hughes cam.
Thanks for the response. I did do a recheck on the cylinders and i was off they came back 2,4,8 at 120. Number 6 came in at 135. 1,3,5 also came in a little over 120 and 7 was at 130. The heads are only a few years old with less then 5k miles on them and the valves were increased over stock with 69cc chambers. Doesn't burn oil or blow smoke. I do plan on doing a ring job over the fall/winter. I'm sure it's a timing issue like i said i'm not expecting a strip car just a nice cruiser but i would like to be able to smoke the tires from time to time just for fun. Factory manual says 135-155 is the factory compression. Let me know what you think.First off welcome to the forum its nice to have you!
What you are experiencing is a classic case of too much cam! Your cylinder pressure of 100psi is right on mark with a low compression stock well used 318. Iv owned a bunch of them I know all to well lol. That cam is probably to much cam for a mild 9:1 360. Your probably at 7.5 to 8:1 but there is stuff that you can do. Without changing gears or converters. Timing is gonna be your friend. @318willrun is running 20 initial and like 40 total in his 318 with low compression you can get alot more than 12-14 . We can work on the tune and get some more out of it. But don't expect a whole lot
More than what you begain with. When I first started my 318 build alot of members told me start with getting a tight sealing engine before worrying about cam and bolt on stuff. They are right. A good hone and ring job (depending on the shape of your cylinders) and a valve job make sure they are sealing can go a long way on a budget 318. You can't afford to loose any more compression due to a leaky valve or ring! Recheck all your cylinders with the throttle Wide open. Then report back if they are above 100 and consistent then chances are you have don't have any broken rings or bad valves. We can raise your compression a little with some thin headgaskets, do you know what gaskets your using now? After we determine all that we can work on tuning your carb and timing.
Those are not bad numbers for a 318. Do you have basic tuning tools like a vacuum gauge and a timing light?Thanks for the response. I did do a recheck on the cylinders and i was off they came back 2,4,8 at 120. Number 6 came in at 135. 1,3,5 also came in a little over 120 and 7 was at 130. The heads are only a few years old with less then 5k miles on them and the valves were increased over stock with 69cc chambers. Doesn't burn oil or blow smoke. I do plan on doing a ring job over the fall/winter. I'm sure it's a timing issue like i said i'm not expecting a strip car just a nice cruiser but i would like to be able to smoke the tires from time to time just for fun. Factory manual says 135-155 is the factory compression. Let me know what you think.
Yes i do. I've got a AVS2 650 on it now it came with a Holley 1850 electric choke 600. The previous owner got into some bad gas and it was just filthy and i couldn't get it to act right. Of course after i removed the fuel tank and found it was full of rust did i find out why. Either way at 14 degrees and fuel mixture set up i'm getting right at 15inHg of vacuum at 750 rpm. When i'm cruising at 50-60 I'm running at 2200-2300 and not sure if that's where it should be or not. I have 3.23 sure grip rear and 3 spd auto trans.Those are not bad numbers for a 318. Do you have basic tuning tools like a vacuum gauge and a timing light?
Thanks for the suggestion. I think I'll keep the cam i've got. like i said it's got good response. If i have to build up to the cam i'm ok with that. The heads are aftermarket and the valves were enlarged and the heads have been bowl ported with upgraded rockers and springs.Something like this would make you alot happier.
Voodoo Hydraulic Flat Tappet Cam - Chrysler 273-360 256/262 (lunatipower.com)
Is that cruising at 50-60 mph or degrees on the distributor? at 2200-2300 rpm?Either way at 14 degrees and fuel mixture set up i'm getting right at 15inHg of vacuum at 750 rpm. When i'm cruising at 50-60 I'm running at 2200-2300 and not sure if that's where it should be or not. I have 3.23 sure grip rear and 3 spd auto trans.
If he is gonna go that far he might as well replace the cam that we all have agreed is too large for the combo. We need to try and get it running the best it can with what he has.You need to pull it back apart and degree the cam. I didn’t read where you did that, so you haven’t a clue where the cam is timed. Once you know where it’s timed, you can determine if you need to change it.
It’s going to be hard to do that if the OP doesn’t know where the cam is. How do we know it’s not in at 114, or even 116? You can’t tune that out if that’s where it is.
Yea thats what I ment if he goes that far he might as well rebuild it.Not to mention, if he plans to replace pistons later - why buy a cam now and a cam after the compression bump?
Going to a 102-104 ICL will gain some pressure and low-end while only losing what he's not using (since OP says he's not tracking the car).
I'd advance the crap out of it, then focus on timing/tuning. Once the new slugs are in, a more 'optimal' cam would make a ton of sense. Right now, it's much more of a gray area.
OP should probably start with some pictures of the spark plugs. That should help give some better guidance than blind recommendations at timing and tuning..
