new cam - some specs
Dave NEO
midwest
found this summit cam below was put in by PO in my '68 383 (4bb 600CFM, 67 primary/73 sec., doublepumper, edelbrock performer intake, cast iron exhaust, 3.23 gears) and I am wondering (with my limited engine knowledge/experience) if detail suggests any significant performance improvement over the stock cam? any comments much appreciated.
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-5,500
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 234
Duration at 050 inch Lift: 224 int./234 exh.
Advertised Intake Duration: 298
Advertised Exhaust Duration: 303
Advertised Duration: 298 int./303 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.466 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Valve Lift with Factory Rocker Arm Ratio: 0.466 int./0.488 exh.
Lobe Separation (degrees): 114
Camshaft Gear Attachment: 1-bolt
Computer-Controlled Compatible: No
Valve Springs Required: Yes
Camshaft Manufacturers Description: Fair idle, good midrange power camshaft. Requires 9.5:1 and higher compression, 2,000+ stall, and gearing. Good mild bracket racing cam.
There will be a difference over stock with that cam. Make sure you have the right valve springs.
I saw '452 head HP valve springs' in rebuild notes. rough est on HP improvement w/ cam?
Competition Cams 911-16 Single Valve Springs
Seat pressure: 122 lbs. @ 1.900 inch, Open Pressure: 309 lbs. @ 1.400 inch
  • O.D.: 1.524 inch, I.D.: 1.110 inch
  • Single valve springs with damper
