New engine issues
Mopar General Discussions
  1. dartfreak75
    dartfreak75 Restore it, Dont part it! FABO Gold Member
    8,501
    5967
    Aug 10, 2011
    Virginia
    Local Time:
    12:40 AM
    So the problem is it will idle but when you give it gas it dies? Correct?
    You need a timing light to check the initial timing. If that is ok id start at the carb. Is the carb new rebuilt? Has it been tested on another engine? If it were my engine id try and find a known working carb. Another thing it could be the spacer those spacers can leak. Or it could be an intake leak.
  2. Bill Conley
    Bill Conley Active Member
    28
    9
    Jun 1, 2015
    muskegon,mi.
    Local Time:
    11:40 PM
    Hello, is there black smoke coming out of the exaust when it is running? if so check your float level and/or your needle and seat.
  3. dazedand confused
    dazedand confused Well-Known Member
    171
    47
    Oct 3, 2010
    hollister mo.
    Local Time:
    11:40 PM
    I'll get a spray bottle and while the engine is running I'll squirt around the carb and spacer plate and the intake to see if idle changes. I'll take the carb back off and tear it down and flush and backflush it and check floats etc.
    • Like Like x 1
    • Agree Agree x 1
    • j par
      j par Well-hung Member
      24,688
      12975
      Jul 2, 2014
      Portland Oregon
      Local Time:
      9:40 PM
      This will be easier without taking it apart, are you getting a squirt of gas when you pump the gas pedal? Like is the accelerator pump working?
      • Agree Agree x 1
      • 318willrun
        318willrun Utube channel 318willrun
        15,534
        16667
        Sep 13, 2013
        I'm here
        Local Time:
        11:40 PM
        P.S. - Don't pre-oil and engine by turning it over with the starter. Your rotating the camshaft and all the components. Either use a primer shaft in the oil pump or just start it.
        • Agree Agree x 3
        • Disagree Disagree x 1
        • j par
          24,688
          12975
          Jul 2, 2014
          Portland Oregon
          Local Time:
          9:40 PM
          My finger was hovering over the agree button until you said just start it? I would say either use a prime Shaft or don't start it!?
        • dazedand confused
          171
          47
          Oct 3, 2010
          hollister mo.
          Local Time:
          11:40 PM
          O I almost forgot someone one here was asking me about metering jets and springs. As far as I know they are stock one that came in the edelbrock 600 ? I rotated the engine with no plugs and only the starter hooked up till my after market oil gauge pumped up to 70 psi cold . I will tear carb apart and inspect the numbers on jets and rods etc. The engine after fully warmed up has 50-53 psi oil pressure. Every thing on the engine is new from the performance harmonic balancer down to the spark plugs. So it's got to be a carb or timing=distributor issue?
          • Like Like x 2
          • j par
            24,688
            12975
            Jul 2, 2014
            Portland Oregon
            Local Time:
            9:40 PM
            What elevation are you at?
          • dazedand confused
            171
            47
            Oct 3, 2010
            hollister mo.
            Local Time:
            11:40 PM
            I live in the branson/Hollister Missouri area . Only 3 miles between the 2 cities.
          • dazedand confused
            171
            47
            Oct 3, 2010
            hollister mo.
            Local Time:
            11:40 PM
            No bluish or black smoke out the pipes or smell of burning oil. runs clean out of the exhaust
          • ocdart
            ocdart Inland Mopars Car Club FABO Gold Member
            9,412
            2599
            Nov 5, 2006
            North OC, SoCal
            Local Time:
            9:40 PM
            Hollister, MO elevation is 722' above sea level
            • Like Like x 1
            • j par
              24,688
              12975
              Jul 2, 2014
              Portland Oregon
              Local Time:
              9:40 PM
              Well when you go through the carburetor it should have a stock calibration in it hopefully. if all that checks out then you should be fine. If the carburetor hasn't been looked at then you don't know. The last guy I heard talk about his Edelbrock said something he heard about taking the front Jets and putting them in the back and putting the back jets in the front or something like that and you just can't trust anything unless you see it yourself. Yes that's a good idea to take the carb apart and make sure everything's where it should be. And absolutely make sure it's squirting out those two front little squirters when you push on the gas. That could be completely it.
              If it's a 1406 carburetor it should be just fine with a stock calibration at least to start with at a lower elevation. I doubt if it will be a Max performance effort kind of carburetor but it should run great once it's tuned to correctly.
            • dazedand confused
              171
              47
              Oct 3, 2010
              hollister mo.
              Local Time:
              11:40 PM
              Ok so what does that mean as far as carburetor/ timing ? It's not my goal to sound like a smartass but this a new concept as far as elevation and carbration adjustments
            • j par
              24,688
              12975
              Jul 2, 2014
              Portland Oregon
              Local Time:
              9:40 PM
              personally I wasn't sure of your elevation. I had a 1406 600 CFM Edelbrock here at about 500 ft. I drove it to my son's house in Colorado at over 5000 feet and it sure didn't run the same. We had to put smaller Jets and smaller metering rods and bigger metering rods actually.
            • j par
              24,688
              12975
              Jul 2, 2014
              Portland Oregon
              Local Time:
              9:40 PM
              ^^^it acted as if it was flooding..
            • ocdart
              9,412
              2599
              Nov 5, 2006
              North OC, SoCal
              Local Time:
              9:40 PM
              Yes, they may use synthetic AMS oil for the engine shoot out in the magazine competition, but I can almost guarantee the engines used in the competition were not broken in using synthetic oil. I'll also bet most - if not all - of those "shoot out" engines used roller cams rather than flat tappet cams.
              You need to break in flat tappet cams using oil with sufficient amounts of zinc in order to keep the lobes from going "flat". IMO, You should also continue using either oil with zinc or use zinc additives with flat tappet cams.
              • Agree Agree x 1
              • dazedand confused
                171
                47
                Oct 3, 2010
                hollister mo.
                Local Time:
                11:40 PM
                Before I started my engine and primed it I put a WIX filter on and 2 bottles of comp cam = cam break in oil with the Zink in it and 10w40 mobil1 synthetic oil
                • Like Like x 2
                • mderoy340
                  mderoy340 Well-Known Member
                  2,388
                  1181
                  Aug 2, 2012
                  Melbourne FL
                  Local Time:
                  12:40 AM
                  reverse the polarity on the magnetic pickup leads on the distributor and see if the motor runs better.
                • dazedand confused
                  171
                  47
                  Oct 3, 2010
                  hollister mo.
                  Local Time:
                  11:40 PM
                  Will do
