S Skeletoil Member Joined May 17, 2008 Messages 13 Reaction score 0 Jun 29, 2009 #1 Filter adapter has gasket to engine side, put small plastic gasket to filter side, still leaks, Fram ph43 filter. Any thoughts
S Skeletoil Member Joined May 17, 2008 Messages 13 Reaction score 0 Jun 30, 2009 #2 Solved, small block oil filter adapter plate has square drive inside the thread tube. I wasn't get it tight enough with a pipe wrench on the threads, I didn't want to gouge them.
I idrift Well-Known Member Joined Apr 29, 2009 Messages 469 Reaction score 2 Location earth Jun 30, 2009 #3 ditch the fram filter, they will not do your engine well.
