New Guy quick question~
Drdodge
New Member
Ok here's the short of it ..im narrowing an 8 3/4 custom lenght and same with the axles...QUESTION: How far from the Sidegear axle on an 8 3/4 should the end of my axles end up? whats the factory distsance?
69signetv8 said:
Not to sure about the word "custom set-up" until the job is completed.
This link has alot of info to get you measured up and started
http://www.moparstyle.net/technical/834.htm
To answer both question Im using stock type bearings with adjusters, and the axle lenght in not the issue its the distance from the differential side gear axle to where my splines need to be Or does the diff axle take up side thrust along with the adjuster on the bearing Similar to C clip type axle's~ :scratch:
Soory if im not clear on this getting this from in my head and on paper to text is not a smooth transition for me~ :scratch:
OJ and a 489 case~
