I've been having some problems with my stock dash and cluster. The dash panel in which the instruments reside is itself breaking down heavily. It chips pieces off daily.
Additionally and more importantly, many of the instruments themselves are dodgy or just plain don't work. Water temp works most of the time, but is extremely hard to see behind the yellowed glass, volts are also hard to see, and fuel level rarely works at all. Further, and of ultimate importance, the speedometer and odometer don't work. This could cause issues. Expensive issues called tickets.
So I have decided to replace the panel itself with a Redline Gauge Works panel, then stuff it with Auto Meter instruments. My questions come thusly after my long-winded explanation:
Does my '71 Demon slant-six/904 come with sensors for short-sweep electrical gauges?
Are any of these gauges going to cause me issues with any of the stock equipment
I want to install a speedometer, tachometer, water temp, fuel level, oil pressure, voltometer, turn signals, and high beam indicator. I just wanted to make sure that every gauge I have will have or can have a sensor fitted to accomodate electric gauges.
Thanks.
Thanks.
