Dodge72
Odd one out
I've seen some mixed things on when installing a new oil pump. I got a 360 and just for good measure I got a new standard oil pump from Melling. I will be priming it... Better on the block or on the bench? And I've seen a few people mention they take apart new ones to clean them. Is this standard procedure or is there a way to clean it without having to take it all apart? First complete engine build with all new parts, making sure I'm doing the right things. Thank you!
