mr.318
i had i post awhile back my new engine wiped cam lobe a 318 40.over zerodecked kb167 pistons areoheads 202 valves anyway cleaned her up another new pump just in case put my cranecam 454 lift matching lifters + added adjustable rockers i was worried bout all the millwork took the 750 carb off put new holley 600 on now it's not hitting on #6 runs the same with plug wire on are off u can hear it out the pipe on that side i call it a flat sound i've changed the plug + wire no help put the old plug on the wire put close to ground cranked it up firing good clyinder still dead pulled all plugs did compres..test all clys.170 pounds but #5 166 pounds means all my valves are ok right?#5 is the cyl. that cam lobe was wiped out i've checked the firing order replaced the cap rotor wires plugs checked the valve adjustment more than once checked timing i'm confused need help newmopar dist. to
