new noise from 727
rigger3006
north america
when I accelerate hard to 4 or 5 grand in lowgear on my 727 and back off right away I get a loud clicking noise from the tranny? I think. just installed new 355 diff but I don't think its that. admittedly though I ran car for maybe 1000kms without kickdown, which is no longer the case, just installed bouchilon cable system.. any thoughts?
...........if it didn't do it b4 the gear install, best to check the drive shaft for a bad / improper installed u joint or ur gears or axles...........kim....
its possible, just talked to tranny shop and they said it doesn't sound like the problem is there..think i'll pullout driveshaft and check front ujoint, I've ignored it last two diff changes!
