New plug wires question
ValiantOne
West "By God" Virginia
I'm needing some new plug wires to go with my gm ignition upgde.
The current wires have the male end that plugs into the female cap. I am wondering if I can get a cap with the male ends for my distributor and the appropriate wires to go with it.
Is there any advantage or disadvantage to this? I figure this way I could get a really good set of wires and then use them on my 360 Magnum EFI motor when I do the engine swap.
Can anyone recommend a good cap and wire set for this purpose? I will likely need to make a longer than stock coil wire as well.
Oh, and will I need a different rotor?
Thanks for any info/thoughts.
CE
Man, no love!!! :P
Let me try again. Does anyone know of a mopar sb distributor cap with male ends on it?
All the ones I find seem to have screws for retention and not the spring clips my unit has.
Thanks,
CE
i prefer the male terminal on the cap.. they just seem to clip in better to me..
think summit also sells them but didn't have time to search..
Custom Wire Sets & Performance Products :: Ignition Components :: Chrysler Conversion Cap- BLK
