New rear shocks
.75 inches shouldn't matter, but what is you intended use of the car. I don't recognize that brand of shock. To me it looks like a cheap shock advertised in a performance catalog for a hot cheap price. If you want to spend about $40 buy KYB's. I think kybs are a little harsh. If you want a really good shock buy bilsteins they are available from firmfeel.com for about $100 each. I know that sounds like a lot of money, but do some price shopping for a shock for a newer car like an avenger,taurus,camry,accord,etc and you will see that $100 per corner isn't that bad.
Im with MCNOOPLE on this one. I would go with the Bilsteins, its money well spent for the quality. We carry them as well
Thanks
James From PST Marketing
1-800-247-2288
Ext 316
Remember to use you member discount.
I can concur the KYB are harsh on the rear end. I have them on all four corners and the front feels fine but when it goes over the back they hit hard. Are the Bilsteins "softer"?
Ok so I am doing the engine swap in my but and Got some new leafs that are going to raise the rear of my Duster a bit.I have air shocks now and really like them but they ride a little stiff.Could I use a shock thats a little taller then stock like around .75 to a inch taller.
http://www.summitracing.com/parts/EXP-924503/
i have a new set of monroes that you can have for $20 if it will help
