moparmat2000
2 pairs of shock plates for mopar 8.75 and ford 8.8. These are made to fit a mopar 3.0" axle tube and the ford 3&1/8" axle tube. Made from 1/4" thick steel plate that has been bichromatized to help prevent corrosion. Leave as is or paint to suit. The holes are slightly ovaled to allow these to work with both types of U bolt assemblies.
Computer model in picture below shows plate attached to a 3.0" axle tube. You can see additional clearancing in the holes for the larger 3&1/8" ford 8.8 U bolts. There is enough clearance for the ford U bolt nuts to tighten down without interference where the plates are bent to 90°. FYI you will not get this clearance for the ford U bolt nuts if you do this by ovaling out a set of mopar shock plates for ford U bolts.
$110 each pair plus $14.35 shipping anywhere in the U.S.A. located in west Texas. I accept paypal.
