i would not totally remove the crank, that is not necessary.
remove the caps (only one at a time). if the journals look shiny, get some plastigauge and use that to measure clearances. you will need to know what the main and rod bearing clearances are for that engine. plastigauge is cheap. basically you remove the cap (only do one at a time) put a piece of plastigauge across the journal, put the cap and half bearing from the cap back on, torque it back to specs. then you take the cap back off a second time, and you can tell by the amount the plastigauge was squished what your clearances are. you will have to do that for each and every main and rod journal.
if you take the cap off to inspect and the journal is gouged or burnt or visibly damaged then it's rebuild time, no need to mess with plastigauge
IMPORTANT:
be very careful that you put each bearing and cap back in exactly the same spot it came from in the same orientation. they are not mix and match once the engine has been run and they are mated to their journal. if you mix them around and stuff you can cause problems. also you must have a good torque wrench and everything needs to be torqued exactly to spec depending on which type of journal you are capping. dont use a cheapo cheap torque wrench.
when finished make sure it's spotless and clean, put a dab of motor oil on it before you cap it back down
http://www.plastigaugeusa.com/how.html
also, it's usually a good idea to put a fresh oil pump in there since you have it opened up... especially if the oil pump rotors have any scoring. a $40 investment...
someone else chime in about the rearmost main cap - i.e. the seal i've never replaced one on a big block, but they are like a 5$ part worth changing while you are in there. i'm not sure if it's easy to change the lower part while the crank is still in
