10 cc bigger runner than the Mopar 190 cc head. 2.05 valve instead of a 2.02 valve. And less flow than the Mopar head. Hmmmmm what’s up with that.
Trick Flow's new DHC 200 cylinder head for small block Chevy is now available!
Build the ultimate classic-looking hi-po Chevy small block with Trick Flow® DHC™ 200 cylinder heads. Patterned after Trick Flow's popular DHC™ 175 as-cast heads, DHC™ 200 heads get the full CNC-ported treatment to substantially ramp up power production.
New 64cc CNC-profiled combustion chambers with 2.055 in. intake valves and CNC Street Ported runners promote big increases in high-RPM horsepower and torque. Bronze alloy valve guides, ductile iron valve seats, and stainless steel valves ensure excellent durability, while proprietary valve profiles and multi-angle valve seat machining maximize flow at low lift. Extra thick decks and walls increase casting strength for peace of mind in demanding conditions. Chromoly steel retainers, 7-degree machined steel valve locks, factory intake and exhaust port locations, and your choice of Trick Flow by PAC Racing valve springs are also standard.
As with all Trick Flow® cylinder heads, DHC™ 200 heads are cast from A356-T61 aluminum to keep weight low. To preserve the vintage theme, exterior touches like straight spark plug holes, castings with or without accessory bolt holes, and other OE double hump head styling cues deliver the traditional look you're going for. Sold individually.
