MrV8Valiant
Member
[video=This is a 273 solid cam 1964 engine with 200 thousand miles]127[/video]
Video: This is a 273 solid cam 1964 engine with 2000 thousand miles
Category: Member Personal Videos
Uploader: MrV8Valiant
MrV8Valiant said:It is basically running well, needs a valve job to be better , and a new cam! seems to be holding together , same as it alwaysa was.... recent timing chain. Still needs a valve job, has a loose valve guide ...but even compression, at 135d Induction otherwise... works well as is. I found a couple loose plug wires on the cap - after pushing them back on it ran better.
