Next Episode of " Name these Parts !"
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Lecanto Florida
First up is a narrowed 8 3/4 mopar.
Total width axle flange is roughly 30 1/4"
Housing is roughly 25 1/4"
and the mounting brackets are at 18"
What would this be for ?
As in Drag car, Pro Street ,
Ladder Bar or 4 Link ?
Solid econo rail ?
#2
Is some 64-67 Mustang Calipers mounted on some adapter brackets.
Summit has these brackets , well out of stock. But doesn't say what they are for .
SSBC-USA A24118
#3 Next up is this Brake valve , couldn't find anything on it ! Is it mopar ? For what ?
# reads Y3 270
And then these bad boys. What brand ? any Ideas ? Uni-mount 4.5 - 5"
Thanks again , for any info on this stuff !
Solid econo rail
The 8 3/4 --- I would call it Bob
2
What do I win?
Looks like disc on 10 inch drum spindles
A153 Front Disc Brake Conversion Kit, Mopar Non Power
Yes. ET unilug. They use a special washer and a short shank lug with a 60 degree seat that registers in the washer. The center hole washers are for a 4-3/4 bolt circle and the offset hole washer is for using 4-1/2 or 5 inch bolt circle. What size are the wheels? They look like 15 X 7.5.
The housing does look like it’s for an Econo Rail, or maybe a Pennsylvania Panzer garden tractor. Does it have some type of back brace?
The axle is definitely not from a Pennsylvania Panzer. The E-T wheel size is cast on the backside of the wheel.
