Snake
Mopar Nut
Thinking of the NGK P#97382 any thoughts worth the money.
OK she is healthyAt $10 each it may sound pricey but they will be the last set you will ever need. Long lasting.
As long as your engine is healthy
As long as you get all of the sand out and there is no damage…Have an antique champion spark plug cleaner one set of r45s last a looonngg time lol.
360 j heads 9 2 1 30 overWhat heads does it have?
That ngk plug has a 13/16" hex
And may not fit in some aftermarket heads.
Factory LA heads would be fine.
Ngk probably has an equivalent plug with 5/8" hex...
I should have started with,
What Engine do you have and what's the build info, use, etc...
Ok the spark plugs will fit those heads360 j heads 9 2 1 30 over
